Hood Stoway In-Mast Furling Manuals
Val B
Nov 16, 2025
3
Kadey Krogen KK38 Patchogue, NY
Good afternoon all, I purchased a Krogen38 3yrs ago with a Hood Stoway In-Mast Furling System. It's a manual system to a continuous line furling winch in the cockpit, which has been flawless except one bind last year. Well the bind happened again, and after a little in-out massaging plastic parts were found on deck ;/ and I was unable to cure the
bind.
I'm looking for any user info or manuals that may be had.
Thanks in advance,
Val
Sep 24, 2018
3,989
Catalina 30 MKIII Chicago
Guarhaugher might be able to fabricate a new part if the rigger doesn't have any stock. If they can't help, PM me. I might consider designing and 3D printing it
Likes: Val B
Val B
Nov 16, 2025
3
I have a manual system, but no continuous line (just crank at the mast). Attached are documents I found that might help you.
Thank you very much, I did secure another copy. It was good to see they are much the same, as I was concerned with different variations throughout production.
I appreciate your effort and assure you I will continue to assist other product owners as well.
Thanks again,
Val
