So I am undertaking maintenance on my Hood SeaFurl 810LD, specifically bearing replacement. I've worked with Marty Barnett at Hood/Pompanette. She's been pretty helpful.
Purchased our Catalina 30T in May 2014. Newbie to big boats, spring was too short and really didn't have a proper sea trial. Oh well... Our Hood furler is difficult to furl in, especially with heavy wind (even pointed in to wind). There is a "hitch" in every rotation. When the breeze is up I have to brace my feet against the cabin bulkhead to be able to pull the dang furling line.
I do use the furler as a reefer also, even though technically it's not designed for that. I find that as long as I have solid tension on both sides of the furling line it holds well.
Anyway, I figured I needed new bearings for the drive assembly. Ordered them off Hood/Pompanette website and consulted with Marty. I ordered a pair of "Part 13" from the owner's manual and Hood website, which is P/N H6120 (the manual has P/N 6181-000).
I took the drive assembly apart yesterday. Ball bearings everywhere!!! 0 But alas, I have 1/4" plastic (delrin?? or torlon??) ball bearings at the top and bottom of the bearing tube. I recovered all of them! However, the P/N H6120 (Part 13) bearing assemblies are not just ball bearings. These have cups/cones (races) and small stainless steel bearings and a little smaller plastic bearings between the SST ones.
My furler is a little screwy, because it has what appears to be half of a halyard swivel assembly affixed just above the drive unit sheaves. This is not shown in the manual. However, the bearing assemblies on this swivel ARE clearly the P/N H6120. I saw another Catalina 30 with the same furler, and it did not have the "half of a halyard swivel" above the sheaves.
See the attached file for pictures and notes.
It would seem to me that I leave off the "halyard swivel" above the sheaves, and replace the 1/4" bearings (I would use torlon).
The conundrum: I am not seeing any wear on the bearing tube races that lead me to believe the bearings were a cause of the rotational hitch I mentioned. The sheave assembly is held firm to the turnbuckle tube with 4 set screws. When I took the sheave assembly off, I found 1 set screw missing, and others loose (annual maintenance note: tighten set screws). I am now wondering if the "hitch" could have been the sheaves wobbling???
I've read the manual even further, and I think I will also have to confirm that the centering collar is located properly, and that the top of the luff sections stop 1-3/4" from the bottom of the headstay wire terminal, and where the halyard swivel is located when the genoa is on.
Any ideas?
Any ideas?
