I have a Catalina 30, vintage 1984, with the Hood SeaFurl 705 LD mainsail furler. I need to learn how and where the furler line was routed. I think I found the furler line, cut into 3 pieces, with several blocks hanging on the pieces. But, I have no idea what goes where, including where on the mast.
I can see how the line ceomes off the furler forward to a block on each side of the mast to route it down the sides of the mast. The starboard side of the lower mast has a fairlead, the port side only a couple of holes that are not very far apart - not far enough apart for a fairlead to be attached. Other than that I have no clues.
The manual instructions have nothing about routing for specific applications.
Do you have a C30 with the mainsail Hood mainsail furler? If so will you help with instructions or a diagram or pictures?
