Honda Outboard question
RacerX
Oct 20, 2008
10
ODay 23 Chesapeake
I have a Honda BF8A outboard that has been very reliable since I got it (circa 2002), but has developed a little problem this spring:
1. Ran fine for the first 30 minutes when recommissioned this spring, then hesitated alot as though starved for fuel or air. I got it running again, and seemed to run fine for a bit. Gas was about 3 hours from the gas station, so not guessed to be the culprit, but was thinking of perhaps some condensate in the carb or picked up in the external tank. I'll try some auto parts dry-gas additive. I haven't checked the plugs yet, but wouldn't seem to be the problem based upon symptoms.... The outboard was fogged and run dry of gas in the fall.
2. (May or may not be related to #1) Outboard did have a transient episode at the end of the fall and once this spring of running along at cruising rpm, then without touching the tiller running up to max rpm, necessitating pulling the emergency stop clip. I didn't try anything else with this yet since I didn't want it to run at max rpm while I scratched my head.... Anyone have any experience with this?
Thanks! If this rain lets up I'd like to use the thing....
Sep 26, 2008
566
- - Noank CT.
while the Honda is a great little outboard I'm betting it is the carburetor. the real culprit is he ethanol in gas. Take the carb off and clean it and I am betting your problem is solved. you will pretty much know when you take off the bowl and see what is inside but still spray the jets clean.
i have to do this to mine every spring and depending on how much fuel is used maybe once during the season. Using some sort of fuel stabilizer (new type designed for ethanol gas like star-tron or marine stabil) will help. It is not so much the new gas but the gas that set over the storage time and all the other gas you have run thru it. I thought Honda recommended leaving the bowl wet in storage and not to run it dry but check you manual to be sure. Not a big job to clean the carb, as far as the other problem not sure if cleaning the carb will help it but can't hurt it. good luck !
Jun 14, 2004
181
Hunter 260 Portland, OR
You might take a look at the throttle linkage, including the tension spring and cabling.
