Honda Inverter Generator
127
Hunter 33.5 Northern Neck, VA
Mayberry's price is $899.00 free shipping and no tax if you are out of State. I am going to get my unit from them unless someone knows of a better deal.
Sep 6, 2011
435
That is better than eBay significantly. SC
Dec 2, 2003
1,637
Hunter 376 Warsash, England --
Guys,
These things are portable and are made for use everywhere including on building sites and the like.
To be able to plug in a drill and a saw - or a planer and a sander and then just pick up whichever is required with no swapping of plugs makes it all worthwhile.
Of course one does not expect all the outlets to be capable of supplying the full current that each plug is rated for simultaneously.
Be reasonable.
Beneteau 323 Annapolis MD
I bought the 2000 with the 20 and 12 v charger. I have never used the charger part. I wish I had gone with the 30-amp CONNECTOR so I could just plug my shore power cord into it. An adaptor is just another potential weak link. As above, the 20- plugs can pop out, and you might not even be aware of it. Get the 30, and if you must buy an adaptor, get a 30M to 15F. Ideally, you would have both (15M>30F, 15F>30M ) on your boat. Perhaps you can find a 8-or-so-foot shore power cord, or use one that has been cut, to make one just long enough to get from the gen to the shore power inlet.
I got my 2000 from Wisesales.com (800-916-9473 for a price) because they were suggested in these forums. You will probably not find the actual sale price on line from any commercial dealer. Fair trade or something like that? Also, pick up the Honda Generator sales brochure and read more about the specs.
Wise was 884.90 when i got it, shipping included to my door in 3 days, but maybe it isn't nowdays.
PGIJon
Mar 3, 2012
856
Hunter 34 Punta Gorda
Where exactly is everyone keeping their extra gas for an extended cruise? Lashed to the life lines?
xcyz
Hunter 376
How with a "ham" radio call?
the companion model is designed to use the mating cable so that you can parallel two 2000's to get higher capacity....that is all the companion does for you...so UNLESS you plan on running two H-2000 at the same time....
BTW, you can usually get them a bit cheaper at Mayberry's Hardware....and even more off with a ham radio call.
They ARE quiet and reliable
Please tell us more, how with a radio call?
Thanks
Aug 28, 2007
127
Re: How with a "ham" radio call?
Just received my 2000i dual plug model, I got the generator, sunbrella honda marine cover, theft deterant handle and 12v battery charger cables (the cables were thrown in), taxes and freight included all for $960.00 from mayberrys.com
Honda does not recommend synthetic oil but mobil 1 says not a problem. What are you guys and gals using for oil?
Feb 6, 1998
11,772
I would recommend listening to Honda... They build perhaps the most reliable engines on the planet and suspect they know a bit more about their engines than another company.
A local guy, "Million Mile Joe" drove his Honda Accord to 1,000,000 miles on regular oil, my dealer serviced his car. Engine was never re-built.... 1,000,000 MILES on regular Dinosaur oil !!! Listen to Honda.....;)
Mobil oil also told me I could safely convert high mileage cars to synthetic. After doing it three times on three different cars, which had all been bone dry prior to synthetic conversion, they all leaked within weeks of the conversion. On the third one I was ready for it and took it to the dealer before conversion to confirm it was bone dry. Not a single oil leak! I got under there and looked myself. Once again within weeks the turbo seals were leaking then the valve cover, then the oil pan..... Took me three of these events to realize it was a dumb idea...... I'm a slow learner....:cry:
Dec 15, 2011
103
Oday 20 SF Bay Area/Monterey Bay
Exactly. When all else fails, read the directions.:)
Aug 28, 2007
127
Honda 2000I
Is this steel overlay something that can be added?
This is what it is: I got mine from Mayberrys.com
Theft Deterrent Bracket
$39.99
Honda metal guard is designed to prevent the theft of your high dollar EU2000i and EU2000i Companion inverter portable generator. The bracket allows you to safely run a chain or cable through the handle of the generator without the worry of someone sawing through the handle to steal your unit. Generators sold separately.
* Heavy Gauge Steel
* Tamper Resistant Mounting Bolts
* Genuine Honda Accessory
RECESS
Dec 20, 2003
1,509
Catalina 27 . St. Mary's Georgia
Where is the best place to get the 20 amp receptacle to 30 amp shore power pig tail online. "Best" meaning quality but at a low price.
I don't think you'll find a "20" straight-plugM to 30F, probably a 15 to 30 is what you'll get. I think it was Home Depot or Lowes that had some adaptors for 9 bucks? They are a clear plastic. Sinc the 2000 puts out 13.3 amps, tyou're okay.
Dec 30, 2009
680
jeanneau 38 gin fizz sloop Summer- Keyport Yacht Club, Raritan Bay, NJ, Winter Viking Marina Verplanck, NY
I am confused with all this, R u saying u can get a plug to plug into shore power fitting and run thru the a/c panel and outlets? Then there is one with a built in inverter to convert to 12Volts?? Red
