Maine I'm not talking about disabling the breaker as that would be a fire hazard; I'm just talking about modifying the section that controls the ELCI function to give the boater the ability to switch it Off. It can be made to default back to On automatically once power is disconnected. This would allow the temporary use of popular portable generators and other un-bonded appliances . It would obviously leave it up to the boater to consider the circumstances when to use it or not. This seems to be the part that concerns the promoters of these changes as it seems they don't trust anyone to be informed and act responsibly. I think in fact that what is bound to happen is that some are going to replace their main breakers with non-ELCI units as an owner modification. ABYC is not a Government Agency and its Standards to not carry force of law. As of today the USCG is not requiring the use of ELCI breakers. If there is a way for us to take a step towards greater safety without sacrificing sensible options then I think the public will accept those enhancements but if you tell me that only solution is for me to install a costly marine generator I don't have to abide by that.
IMHO a portable gas powered generator on a boat is far from "sensible" despite their wide spread use. Using the terms safe and sensible in when referring to portable generators on boats gives me a chuckle..
I own an EU2000 and it will never set foot on my boat.. Something about Darwin awards...
They are unsafe on many fronts, not just from the electrical compliance side.
Personally I do not buy into the poor
boater argument for safety issues: A) You can afford a boat B) you can afford to slip it, maintain it C) you can afford to have air conditioning installed
But now you can't then
afford to use acceptable safe wiring practices? If you can't afford them on your current boat perhaps buy a smaller one that costs less to maintain and that you can maintain safely.. An RGP for a Honda would run you all of $1.09 to make...
In my experience boaters
generally choose what to spend money on and the decisions are rarely based on being safe.. I had one owner who knew he needed new standing rigging (3K) he opted for a paint job (10.5k) instead. He then argued he could not
afford new standing rigging. No, he made a choice to make his boat
look better, not for it to
be safer. Lucky for him it was a lower shroud that failed and he did not lose the rig....
Those same arguments, I can't afford it, are what forced states to have automotive inspection programs to help keep our roads safe. People choose safety, or they gamble and don't...
While the ABYC is absolutely
standards organization much of what the ABYC has done in terms of safety is directly incorporated and has been adopted by and into the CFR or Code of Federal Regulations. It's work expands regularly into the CFR. I would not be surprised some day to see ELCI's mandatory just like USCG/ABYC A-16 navigation lights are for new boats.
The real crux is that insurance companies and their surveyors follow the current acceptable safety standards whether we like it or not. I realize most don't like this, so I suggest taking it up with your insurer. BTDT.....
Regardless of whether something is safe, economical or the law the insurance company is usually the final word if you want to retain coverage. No the ABYC and USCG will not come banging on your door but the insurance company may just drop you if you don't bring your survey findings in line. If you've not had an insurance survey in a while, DON'T CHANGE INSURERS!!!
In the last few years, from insurance surveys alone, I have had to:
*Bond a keel stepped mast to external ballast (after a strike claim & this is NOT a standard)
*Bond numerous boats for AC Grounding to DC Grounding
*Add over current protection where it did not exist (house banks for example)
*2 Boats for the 10' rule (AC shore power inlet rule)
*1 Boat for an improper AC main breaker (not double pole)
*Multiple boats for GFCI outlets
*Multiple boats for lack of DC over-current protection
*Multiple boats for LPG system issues (too many to list)
*1 Boat for AC/DC isolation (cover for AC) behind AC/DC panel
*Multiple boats for fuel system issues (too many to list)
*1 Boat for lack of a reverse polarity indicator
*Approx three boats for non compliant battery chargers
*2 Boats for ignition protection issues on gas boats.
*1 Boat for lack of a bilge blower
*Improper bonding of chargers and inverter/chargers
*2 Boats for a bilge pump alarm
*Multiple boats for deteriorated below waterline hoses (one just last week)
*Remove a non compliant on-demand water heater (Excel)
*Multiple battery system compliance issues including venting, acid containment, over current protection etc..
*Multiple unsafe termination issues (solder, wire nuts, tape etc.)
*Steering system failures (meat hooks etc.)
I had one boat, a Pearson 30, condemned by water intrusion into the decks and around the chain plates. The fix to the boat was more than the boat was worth. No one would insure it. Boat is now a derelict. If you think the ABYC safety standards don't have any weight on boats this would be wishful thinking.. I get fix this stuff regularly including items that are not even required under the standards...
There are many more that I am just forgetting... Insurance companies and surveyors today are playing a CYA game. In today's day and age it does pay to use the available safety standards as a solid guideline for boat upgrades. The survey industry uses them so the closer your boat is to those guidelines (ABYC) the better chance you will have at skating through clean on an insurance survey. It is getting tougher and tougher to find a "lick & stick" surveyor these days due to the litigious nature of our society.
NOTE: "Lick & stick" is a term for those of us in states that require State inspection stickers on cars. Anyone who's ever owned an old car knows what a "lick & stick" garage is..... A few extra dollars and the problems just go away and he licks the sticker and slaps it on... (wink)
Again if you want your a Honda to work with certain breakers and equipment then a Rube Goldberg Plug is the best $1.09 solution you will find..
