Replacing it?
So Alan, are you going to replace it? Or keep it out for the weight savings and have the crew use the old bucket and chuck it method?Just kidding!Yes, I also went Ronco when I replaced the tank in my H35.5. I went from the 13 gal original aluminum to a 25 gal poly tank that fit like a charm. A couple of small tricks to get it in, but very glad I did it. Ronco will place openings where you ask, with the sizes you need. Went with all fittings on top, dip tube for the outlet and a 1" fitting for the vent tube. I was running all new hoses, so replaced vent with 1" and a larger thru hull in the original location.T JT J
