holding tank guages
11
- - Amelia Island
I have a Hunter sailboat, and guages on holding tank seem to get stuck regularly, so hard to know when full. I have heard Calgon helps, any other suggestions?
May 28, 2005
15
Hunter 376 San Diego
Remove, clean, replace...
Remove, clean, replace... there are detailed directions and comments on the archives here. Alternatively, replace the gauge system with one from Snake River. Their sensor is metal foil on the "outside" of the tank. It will never get clogged with the fatty material inside the holding tank. Good Luck, Scott
Jun 7, 2004
383
Schock 35 Seattle
Marine Sanitation
Marine Sanitation in Seattle sells a system of three sticky pads with wires in them that you just stick to the outside of the tank. A wire runs to a small panel which lights up to show the level when you push the button. Ours has worked flawlessly for several years now. One thing I like is I placed the top sensor a little lower than the top of the tank so I still have room for a flush or two when it reads full. System offers great flexibility. I don't think this gadget is in M/S catalog so you will have to call them. http://www.marinesan.com/
Dec 2, 1997
9,010
- - LIttle Rock
Check out the Profile gauges
http://ferriellosales.com/default.php Exceptional quality and outstanding customer service for a very reasonable price. And, their senders are compatible with most other panels, making it unnecessary in most cases to replace anything but the sender. Btw...Snake River is out of business.
dennisferriello
Profile Gauges
Peggie: Thanks for the letter. Just to let you know that our Profile Legacy Panels are standard equiptment on the Catalina 309,320,350,387,400 and the 440. Also our sensors are like Peggie said compatable with the old Snake River units. Dennis Ferriello
