I have a Hunter 326, 2003 and the holding tank has developed a leak.
Does this job stink! There is a crack on the top of the female fitting that attached to the macerator discharge hose. Can a crack in the fitting be repaired? (pic below) I know other have said they’ve used 3M products on a PE tank with success but the fittings? I’m concerned about the constant stress on the fitting and it's on the bottom.
Next issue is getting it out, 20 gal tank and a tight cabin door on the 326. I removed the door which got me closer but still can’t make the turn. Anyone have a suggestion? I’m looking at removing the wall between the head and aft cabin which looks like a huge job.
I'm Stuck
I'm Stuck
