Hitch extension
362
MacGregor/Venture 25 Winthrop Harbor, IL Drummond Island,MI
Well........without getting into the physics......unless you want to......I don't think your hitch will be up to the leverage. If you use a square tube with adequate wall thickness....and you have the proper tongue weight times a six foot lever......something on that hitch is going to be upset with you. Cut your tongue off the trailer.....insert your six foot tube....drill the required holes for bolts/pins.....cut a square hole in the back of the crossmember so the tube will slide through.......you will be happy with the result. If you want....I can take close up pics of mine.
Kermit
Jul 31, 2010
5,722
Love to see pictures. Thanks!
