Next: Take that old crusty gooseneck fitting to a place that can "hard coat anodize" it, after you clean and wire brush it well. Then reinstall with a different type of pin or bolt......
								Ingenius!My '83 cat22 has that setup. A clevis pin will hold the sail in place but the long "tang" is to hook the grommet when reefing. You'll need to rig an alternate way of holding the grommet in place when reefing..
That's the standard Catalina pin. Heat the fitting as you use an ez out to extract the remaining part. Repairs vary from a bolt to a pin as recommended. If you use a bolt (that what I have) I recommend that you thread a wing nut on it up to the bolt head to make a nice handle. The bolt / pin should go hand tight and then pack 1/4 turn. It should be easily removed for reefing, sail changes, etc. It should be checked occasionally for binding and be replaced / lubed if needed. Same goes for your rivets and things on your end cap. That boom looks like it has seen some substantial salt spray so other components may need a little TLC as well.Update - after brushing, application of PB blaster and a few whacks with the rubber mallet, we did get the tack pin to turn and it was threaded on the opposite end. Unfortunately, a portion of the scre remains stuck in the oppisite eye. Will go back with a drill in a few days. Instead of resinstalling thia same type of tack pin, I will probably just install a bolt. Will post again when done in case anyone is curious. Also here is a pic of the portion of the pin we were able to extract.
One of these would workMy '83 cat22 has that setup. A clevis pin will hold the sail in place but the long "tang" is to hook the grommet when reefing. ..
