You have to start in the fall.
The way to do it is to run messenger lines -- strings -- through the organizers. You attach them to the halyards, reef lines, etc. as you remove them when you unrig. When you re-rig in the spring, you just tie the messengers to the rope and pull it back into place.Of course you can't do that now.You have a couple of options, not counting locating a trained hamster.You can remove that top panel by simply removing the screws that hold it on the deck. It's not something you want to do all the time since the screw holes get worn out, but once isn't going to hurt. If you removed the screws and can't get it off, they probably caulked it. You can still pull it off, but you'll have to get the caulk to release.You can get a long flexible rod, like electricians use to run wires through existing walls. Visit your neighborhood home depot.Lesson learned for next year. After a while, you'll figure out there is no point in having your mast unstepped, and you can avoid the whole mess.Good luck!Paulsv Escape Artisth336
