Help - Interior wood finish lifting
Jun 23, 2013
271
Beneteau 373 Newport
The varnish on the wood panel at the fwd end of the vberth lifted during winter storage (2004, 373, Douka wood). I searched the forum and THANKS Gunni for the wood repair document. However, can anyone provide info as to the cause of this failure? I don't want to have this happen again or in another area.
Thanks,
Bob
Jun 19, 2004
365
Island Packet IP 32 99 Forked River, NJ
Never worked with Douka wood but looks like the surface wasn't properly prepped before varnish was applied.
Likes: justsomeguy
Jun 21, 2004
3,104
Beneteau 343 Slidell, LA
Yikes! I have heard that there was a problem with the catalized lacquer that caused it to fail. I have seen photos of bubbling; however, yours seem to be exhibiting total failure. Hopefully, it will be easier to remove.
I would sand it thoroughly with 150 & 220 grit paper and thoroughly vacuum and wipe down with a tack cloth, then wipe down with denatured alcohol ( ventilate thoroughly), then follow the Beneteau refinishing procedure that Gunni posted.
My 06 Ben 343 has not shown any tendency for the finish thus far.
Jun 23, 2013
271
Jim & BigEasy,
Thanks for he replys, but the boat is over 11 years old! From what I read this should have happened along time ago if it was an application or lacquer problem.
I'm concerned that something recently caused this, which needs to be remedied. BUT what?
Gunni
Mar 16, 2010
5,937
Is this de-lamination problem just in that location? If so, I would suspect excessive moisture that got into the wood.
Jun 23, 2013
271
Delam only on this one piece at fwd bulkhead of vberth. Rest of laminate like new. I will look closely again for any signs of moisture.
No heater.
Jun 23, 2013
271
Woodster,
Yes and the panel in the white trim in the 1st pic opens to the windless motor. But finish on that panel is not lifting.
Did confirm that the anchor locker drain is open.
Jun 23, 2013
271
Also, will confirm tomorrow but th aft wall of the locker is fglass and don't think there are any protrusions to the wood.
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
well something is rotten in denmark....do you have any delamination in the plywood
Jun 23, 2013
271
My first answer is no from when I looked at the visible surface. Will remove the lifted varnish when I get back to boat tomorrow to confirm
