Help changing impeller
Mulf
Dec 2, 2003
400
Hunter 410 Chester, MD (Kent Island)
Not sure if this available for all engines but...
an impeller is now available for my 4jh3e Yanmar (Johnson Pump I think) that has a threaded section on one end of the impeller. There is a very simple puller available that has a bolt that sits on the hub and an outer nut that screws in the threaded end. Just turn the bolt with a wrench and the impeller is pulled out. None of the efforts described in this thread that could result in damage to the housing.
May 20, 2004
151
C&C 26 Ghost Lake, Alberta
I have a 2GM20F with a raw water pump like yours.
I remove my impeller every winter when I winterize the boat - Canada/-30 in January!
I don't have any problem getting out the impeller, so I suspect it's either the salt water (I'm in fresh) or the PO hadn't changed it in a long time.
I suspect if you do it regularly from now on, a pair of long nosed pliers will be all that's needed.
Sam :)
