Heat exchanger cleaning
Johnb
Hunter 37-cutter Richmond CA
I have removed the heat exchanger from my Yanmar 3QM30 and need to get the core cleaned. Can anyone suggest a shop in the San Francisco East Bay area?
Thanks,
John Brecher
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
is that a QM or GM heatexchanger... if GM you can clean it your self by roding out the flews like you would a 22 rifle dont know about the QM.....
regards
woody
cbrey
Oct 21, 2011
1
Hi there, I just removed the heat exchanger from my Westerbeke W13. I'd like to go the chemical descaling route. Had anyone used the commercially available products like Barnacle Buster or Rydlyme? If so, what is the exact process? Does the stuff have to be pumped through the core under pressure, or can it simply be poured in through the raw and fresh water ports and allowed to soak, with the exchanger being turned once or twice to get the stuff through all the tubes?
Thanks,
Carter
Beneteau 323 Annapolis MD
A radiator repair shop will handle the job. Either just boil or acid-wash it.
