Hi there, I just removed the heat exchanger from my Westerbeke W13. I'd like to go the chemical descaling route. Had anyone used the commercially available products like Barnacle Buster or Rydlyme? If so, what is the exact process? Does the stuff have to be pumped through the core under pressure, or can it simply be poured in through the raw and fresh water ports and allowed to soak, with the exchanger being turned once or twice to get the stuff through all the tubes?
Thanks,
Carter
