Hello - I also have a 2004 Catalina with same engine and set up etc. - I've changed the anodes numerous times and although it's not a problem getting out a worn down pencil anode down, I still find that with a little wiggling the new one goes up, whilst rubbing against that mounting bolt. I think once I slid the anode up separately, and then screwed on the bolt base afterwards. Good luck!I have a 2004 Catalina 310 with the Universal M-25XPB engine. It appears I will have to loosen the heat exchanger brackets and rotate it a bit to change out the anode? It drops straight down onto the engine mounting bolt.
I hadn’t thought of that. I guess I can take the end cap off to fit the anode back in the base.Hello - I also have a 2004 Catalina with same engine and set up etc. - I've changed the anodes numerous times and although it's not a problem getting out a worn down pencil anode down, I still find that with a little wiggling the new one goes up, whilst rubbing against that mounting bolt. I think once I slid the anode up separately, and then screwed on the bolt base afterwards. Good luck!
Yes, give that a try if it doesn't want to wiggle up in place as BC mentioned. You could loosen the mount brackets and rotate the HX as you described, also.I hadn’t thought of that. I guess I can take the end cap off to fit the anode back in the base.
The thinner gasket may reflect the progression in the advancement of science in generating new and better materials. As for the not being able to crank it down, try a bronze washer or spacer..
BringMy thought too, thanks. Every time I think I have everything I need for a boat project there is always a part or tool that I didn't think of.
