nope. very similar. just have an o ring kit so you have options.Have small slow drip from faucet in head with switch off at panel. At home usually replace internal washer. Before I get involved any surprises I
should know about? Thanks for any replies.
Clyde Thorington
C310 # 245
I LEAN TOO
San Jose, CA
Thanks a lot folks. Big help.I actually replaced our old one with this. Matched the original and the galley sink faucet.
Amazon.com : Ambassador Marine Trinidad Collection Head Faucet, Chrome : Sports & Outdoors
Amazon.com : Ambassador Marine Trinidad Collection Head Faucet, Chrome : Sports & Outdoorsamazon.com
Looks nice. Did you install chrome sink or did it come with the boat?I actually replaced our old one with this. Matched the original and the galley sink faucet.
Came with the boat. I assume it was the original?Looks nice. Did you install chrome sink or did it come with the boat?
Clyde Thorington
C310 # 245
I LEAN TOO
San Jose, CA
Think original was one formed piece. If you look at Paul J's picture in this thread you will see original.Came with the boat. I assume it was the original?
I’ll bet CY changed it Over the production run. Ours is #31, 2000 vintage.Think original was one formed piece. If you look at Paul J's picture in this thread you will see original.
Mine is like his.
Clyde Thorington
C310 # 245
I LEAN TOO
San Jose, CA
I also got a new shower faucet and head from Amazon. Galley sink I only replaced the sprayer and strainer basket. Sort of pricey, but all looks much better than what it replaced.Neat find, I clicked on the Ambassador Marine name in Amazon and it came up with a lot of plumbing options including the galley too.
Just got delivery of mine. New one has two short 3/8" ? pipes that screw into base of faucet. Didn't feel like came loose from flexible hoses.OtherI actually replaced our old one with this. Matched the original and the galley sink faucet.
It’s been a while since I did that, but I also replaced the PVC tubing at the same time. Pretty sure I used pipe thread to barbed hose fittings to make the connection. Bought a bunch of different sizes and configurations (straight and elbow) from Amazon and McMaster. Pretty inexpensive.Just got delivery of mine. New one has two short 3/8" ? pipes that screw into base of faucet. Didn't feel like came loose from flexible hoses.Other
end have flexible hoses with very large end that screw into hoses from water supply. Did those ends
fit into you existing water supply hoses? For some reason thought water supply hoses were much
smaller and had push in connections with clamps. Did you use those old short hoses from old
fixture and connect to old supply hoses? Thanks for your info.
Clyde Thorington
C310 # 245
ILEAN TOO
San Jose, CA
