Head faucet drip
Clydo
May 28, 2013
371
Catalina C310 SF Bay/Delta
Have small slow drip from faucet in head with switch off at panel. At home usually replace internal washer. Before I get involved any surprises I
should know about? Thanks for any replies.
Clyde Thorington
C310 # 245
I LEAN TOO
San Jose, CA
Nov 18, 2010
2,441
Catalina 310 Hingham, MA
Clyde Thorington
C310 # 245
I LEAN TOO
San Jose, CA
nope. very similar. just have an o ring kit so you have options.
Nov 16, 2012
1,055
Your faucet may have a cartridge, rather than a washer, although there may be o-rings as part of the cartridge.
Clydo
May 28, 2013
371
Nov 16, 2012
1,055
Looks nice. Did you install chrome sink or did it come with the boat?
Clyde Thorington
C310 # 245
I LEAN TOO
San Jose, CA
Came with the boat. I assume it was the original?
Clydo
May 28, 2013
371
Think original was one formed piece. If you look at Paul J's picture in this thread you will see original.
Mine is like his.
Clyde Thorington
C310 # 245
I LEAN TOO
San Jose, CA
Nov 16, 2012
1,055
Mine is like his.
Clyde Thorington
C310 # 245
I LEAN TOO
San Jose, CA
I’ll bet CY changed it Over the production run. Ours is #31, 2000 vintage.
JRT
Feb 14, 2017
2,059
Neat find, I clicked on the Ambassador Marine name in Amazon and it came up with a lot of plumbing options including the galley too.
Nov 16, 2012
1,055
I also got a new shower faucet and head from Amazon. Galley sink I only replaced the sprayer and strainer basket. Sort of pricey, but all looks much better than what it replaced.
Clydo
May 28, 2013
371
I actually replaced our old one with this. Matched the original and the galley sink faucet.
Just got delivery of mine. New one has two short 3/8" ? pipes that screw into base of faucet. Didn't feel like came loose from flexible hoses.Other
end have flexible hoses with very large end that screw into hoses from water supply. Did those ends
fit into you existing water supply hoses? For some reason thought water supply hoses were much
smaller and had push in connections with clamps. Did you use those old short hoses from old
fixture and connect to old supply hoses? Thanks for your info.
Clyde Thorington
C310 # 245
ILEAN TOO
San Jose, CA
Nov 16, 2012
1,055
Clyde Thorington
C310 # 245
ILEAN TOO
San Jose, CA
It’s been a while since I did that, but I also replaced the PVC tubing at the same time. Pretty sure I used pipe thread to barbed hose fittings to make the connection. Bought a bunch of different sizes and configurations (straight and elbow) from Amazon and McMaster. Pretty inexpensive.
