G
Gene
Preparing my Catalina for some offshore cruising but need some help. Does anyone have or seen a 27 Caatalina (with fold down table) with a Y-valve and discharge thru hull for the head. If you do, where is the thru hull placed. Not enough room on the starboard bow as I have speed, depth, and head inlet thru hulls at that location. Two choices appear to be in the port closet (necessitates cutting big hole in liner, not sure if that would compromise strength) or the port bench storage compartment (long hose run and uses up prime storage.)
