I’m attempting to remove my transmission from my Kubota diesel and am not sure where the bolts are that attaches the trani to the motor, any suggestions? Anyone dealt with a Hurth?
No. All the parts are there.It almost looks like the input shaft seal is missing.
Yes and no. The lever is in the traditional position which happened to be upside down for my application.Shift lever upside down?
one of the things that makes no sense until it does and then it becomes crystal clear and you wonder what the big deal was about.
Thank you however the photos show a different trani.Not sure about your unit.
If it looks anything like this the red arrows point to bolt holes. The bolts hold the transmission to the engine.
Bingo! I believe the bowl-like section of the back of the engine needs to be removed, thank you.My dad removed the transmission on our Universal (Kubota block) M12 years ago. I was a kid, but from what I've heard the back of the engine had to come off. I suspect the bolts for the transmission may be inside the bell housing?
