Have you ever ditched your outboard remote?
Oct 10, 2019
23
San Juan SJ 21 Calgary
Hi, I have a 2007 Hunter 25-2 with the outboard remote mounted on the steering helm. The remote and motor are tired, and are due for a replacement. I'm also considering just buying a whole new 9.9 outboard and ditching the remote altogether. The Yamaha 9.9 (long shaft, high thrust) is available with a decent length tiller, and also has the shifter incorporated into the tiller. I would steer with the rudder, of course. Has anyone done something similar? All I use the motor for is getting to/from the mooring ball.
Sep 24, 2018
4,750
Catalina 30 MKIII Chicago
Your setup may be a bit different but I found a properly mounted remote shift/throttle lever to be a big help. It keeps my eyes on my surroundings instead of looking for a tiller
Ward H
Nov 7, 2011
3,843
I had an Oday 25 that came with an inoperable remote setup. The motor also had many issues.
I ditched both and put the Yamaha 9.9 High Thrust with Long Shaft on and loved it. One of the reasons I chose the Yamaha was that the shifter was on the tiller. I wouldn't put on a motor with a side shifter. Choose the power tilt option, you'll love it. It is a heavy motor to tilt manually.
I only used the motor tiller to help steering into/out of a tight slip but once out of the slip I left the motor straight and steered with the boat tiller.
Sounds like a good choice for your boat.
Sep 17, 2022
232
Catalina 22 Oolagah
Not all tiller mounted shifters are made the same. Both the Yamaha and Tohatsu have the shifter mounted mid tiller as a push pull shifter. Mercury's 9.9 Prokicker outboard has a twist grip tiller that shift the engine between forward/nutral/reverse this affords great speed control when docking.
George
