hatch board material
Kivalo
Jun 5, 2011
116
Hunter 260 Owasco Lake
Does anyone know what the companionway hatch boards were made of on a 2003 260? (obviously not the teak hatch boards) I broke one and would like to investigate my options for repair before I replace it.
Thanks,
Brad
Jan 4, 2006
7,819
Not much to go on without a picture but if they're clear, they're 1/2" acrylic as on a '99 H310. There are the nicest IMHO. If they're opaque plastic, they're 1/2" UHMW polyethylene (STARboard).
Maybe a 2003 H26 owner can supply some hard facts here.
Kivalo
Jun 5, 2011
116
They are a dark colored see through plastic. I guess I should have been more specific, there are plenty of different materials out there. LOL brain fart.
Jan 4, 2006
7,819
Piece of Cake ..................
................. as they're either smoke or bronze acrylic. I'm saying they're 1/2" thick, same as our H310. If you've got the broken pieces, they can be used as a pattern. Otherwise you'll have to wing it.
If you've got a hobby woodworking shop, this stuff is a breeze to work with. If not, any plastic shop in your neck of the woods can fabricate the panel for you. However without doing it yourself, these fabricators can be a little pricey.
Kivalo
Jun 5, 2011
116
I was hoping to to bond them somehow if I could. Not sure thats going to work very well though.
BrianW
Jan 7, 2005
843
Hunter 26 Guntersville Lake, (AL)
Kivali, there are some solvent welding techniques for acrylic and polycarbonate. A while back, googled the subject and got lots of info, but didn't actually try it. BrianW
Aug 11, 2011
1,020
O'day 30 313 Georgetown MD
Use AZEEK board. Its lighter, can be worked and comes in regular lumber widths. It bright white and can be painted.
-na -NA Anywhere USA
As for those hatch covers, I tried several times to glue back with various glues but to no avail as a former and top dealer for the 260.
Working with plastics, you have to cut slowly or you will melt the material with a high speed jig saw or any other kind of saw. Also you will need to follow the angle of the edges as they are designed to deflect water.
If you want to attempt this yourself, I would look locally for scraps and if near the coast, I would look thru the scrap piles at marine repair yards as you will get a better deal for scarp vs. purchasing a complete 4' X 8' section which is costly. If the scrap material is scratched, you can wet sand out and to finish off, use a slow speed buffer no faster than 1000 rpm with any good fine compound and I use to use the 3M finesse It paste type but that only comes in a gallon can which can be expensive for a small job.
Brian and Ralph, thank you for your responses gentlemen. Brian and kermit, my mountain home will be finished by the end of September. Kermit and Brian, you and others will be welcomed to stay and be prepared to be wined and dined like my family at the farm for years did. The beginning of the James River in VA is literally in my back yard with superb mt. views.
Nov 26, 2012
1,654
C&C 40-2 Berkeley
hardy back
I replaced the hatch boards on my H25.5 with ones made from hardy Back siding. Not see through but very durable. I just painted them a color that matched the trim on the boat. Looked great.
May 12, 2014
10
Hunter 23 Darien
Hi - I am also looking to rebuild my companionway covers. Can you provide more information on AZEEK board. Could not find it referenced. Where do you buy it?
Thanks
Ha Ha Justsomeguy. Welcome is spelt welcome. Opps. I misspelled spelled.
Have a great and wonderful day. I was just in a fujnny mood this mornin.
