Inflatable
There are pros and cons. I have the same boat, only an '87 and I'm happy with my inflatable. It is an older West Marine model with wood floor boards. I keep it up at the pointy end of the boat and lash it down to keep it in place. It is very stable which is important to me safety wise. The biggest con is if you intend to take it to lots of remote areas, dragging it up on rocky beaches with barnacles can lead to wear and tear on the bottom and potential leaks. Mine has lasted for years and I've only had minor leaks which I've repaired easily. If you put a small outboard on it, it won't move as fast as a hard dingy, but speed wasn't high on my list. Check out the swap meets in the area that occur locally. Often you can find a good used one for a decent price. Anacortes is having a swap meet on Sunday, May 21st, 10am. I saw two nice ones there last year. Good luck!!
