Halyard selection
Jan 22, 2007
11
- - Marina Del Ray
We need a new main halyard for our 22 year old 45’ Hunter Passage 450. Not racing, just local/coastal cruising. Trying to figure out what size is best - 11 or 12 mm, 7/16 or 1/2”. And what material. Thanks much. C
Aug 17, 2013
386
Granpian G26 Cool whip Ottawa/Gatineau
I would go for the 10mm, way stronger than what you need, you could probably get away with 8mm, smaller in the hand but lighter on the wallet
Jun 25, 2004
818
If you go with halyards that are smaller than what you currently have, Check to make sure that the rope clutches are compatible smaller diameter line. Clutches are made to hold specific diameter lines.
CAL 35 Cruiser Portland OR, moored EVERETT WA
What @DrJudyB says...:plus:
Of equal consideration, you are talking about a halyard. You will want to be sure that the size is compatible with the size of your mast sheaves. Too big and they jam or provide friction making raising and lowering a sail a problem.
Likes: tfox2069
Jan 22, 2007
11
- - Marina Del Ray
Thanks. I might go with 11 mm or 7/16”. The’re just about the same size. It’s either one of these or 1/2”.
Jan 8, 2015
345
MacGregor 26S, Goman Express 30 Seahorse Kerr Reservoir
Now that you have the size selected, double braid polyester with a dyneema core would be one choice to consider for your application. Low stretch but still good handling characteristics.
Slickcraft 26 Greenport, NY
Racing doesn't really matter. You want a halyard that doesn't stretch much. And I mean very little. A halyard is a sail control and if it stretches in gusts or higher winds your sails won't perform as well making your boat more tender and likely to misbehave. I would venture to say that the best money spent on running rigging is on halyards. Runner up might be reefing lines.
Likes: FastOlson
JRT
Feb 14, 2017
1,629
Catalina 310 211 RoseLeigh Lake Guntersville, AL
I second SBO store, they made some nice lines for me!
Likes: Dalliance
And I usually order my halyards with a shackle spliced on one end. That makes a nice clean installation.
