Hello,
On my 2003 Hunter 44 DS I have two fuel tanks: one on Port Side (filler in the middle of the deck) and one on Starboard (filler Aft). Recently I filled the Starbord one, with 90 liter and noticed the port side was full (did not accept fuel). 10 days later while filling it was the contrary : Starboard one was full and had to put 200 l on the port side. I do not record having changed any valve or so.
Questions:
Are there any valve system (or pump) to select which tank to use ?
Where are these valve or pump switch located ?
What are the capacity of each tank ?
Thank You
Henri
Questions:
Thank You
Henri
