H44 DS How do the 2 fuel tank work ?
henris
Oct 12, 2012
12
Hello,
On my 2003 Hunter 44 DS I have two fuel tanks: one on Port Side (filler in the middle of the deck) and one on Starboard (filler Aft). Recently I filled the Starbord one, with 90 liter and noticed the port side was full (did not accept fuel). 10 days later while filling it was the contrary : Starboard one was full and had to put 200 l on the port side. I do not record having changed any valve or so.
Questions:
Are there any valve system (or pump) to select which tank to use ?
Where are these valve or pump switch located ?
What are the capacity of each tank ?
Thank You
Henri
Oct 1, 2007
1,865
Hello,
Questions:
Thank You
Henri
Henri
The tank you are pumping fuel into on the port side is where my holding tank pumpout fitting resides. Are you pumping fuel into the waste holding tank?
Rick
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Do you have one or two diesel fill locations? Is the boat new to you and did the surveyor provide any information on the two tanks ans would be expected on a survey?
BrianH
Feb 14, 2005
104
Hunter 44 LaSalle, MI
My 2005 44 has port and starboard fills for the two freshwater tanks. These fills are in the same spot on either side. If your "diesel" fill on the port side is located opposite the starboard freshwater fill you have one of two scenarios.
1. Prior owner made modifications to add additional fuel capacity and/or easier fuel fill access.
2. Prior owner lost the freshwater fill cap and replaced it with one marked "diesel". :yikes:
One way to find out for sure is to switch off your starboard freshwater tank and run the water in your port freshwater tank.
henris
Oct 12, 2012
12
Indeed the water tank was replaced with an extra diesel one once a desalinator was installed
henris
Oct 12, 2012
12
Assuming that the water tank became a Diesel tank of same capacity, what will be my total content of Diesel and content of Water ?
Oct 29, 2016
1,929
Hunter 41 DS Port Huron
The original diesel tank is 51 gal and it appears that there were (2) tanks for fresh water with a capacity of 125 gal, assuming the port side fresh water tank was converted to a diesel tank you would have an additional 62 gal of diesel for a total of 113 gallons. I would hope that the person that converted the freshwater tank would have replaced the tank with a tank suitable for fuel:eek:
Likes: sail sfbay
Feb 21, 2013
4,638
Nice math question...............Ditto DayDreamer41 got the answer justa minute before I was going to post it. Suggest consulting the manual I provided a link to above for capacities and water/fuel diagrams.
henris
Oct 12, 2012
12
Tank you all ! My math question was due to the fact that it was not clear in the user manual if the water tank capacity was per tank or for both. Apparently it is fot both. :)
