H41DS decoupling fridge/freezer switch?
Jan 7, 2011
6,018
Oday 322 East Chicago, IN
I assume you have 2 separate compressor units ? One for the fridge and one for the freezer?
If so, I would think you could...but...
1) check the “coupled“ breakers and make sure it is actually 2 separate breakers.
2) let us know what make of refrigerator and freezer you have...hopefully someone knows way more about it then me :huh:
3) Batchelor’s don’t eat frozen pizza or burritos? Who knew...:facepalm:
Greg
fero
Jan 15, 2010
133
Hunter Legend 40.5 Victoria
To change freezer to frige, providing you do have 2 compressors, all you have to do is to replace the freezer thermostat with a frige thermostat. That’s exactly what I have done, but the other way around, as the PO preferred to have 2 friges on my Legend 40.5.
It is surprising that there are not 2 switches, on my boat there are 2.
Good luck
Frank
Likes: Nachismo
Dec 25, 2000
6,071
Different model boat here with two separate units controlled by separate switches. If I drop the thermostat on the freezer to the lowest setting, the temperature in the box rises above freezing. Keep in mind that at some point in the future the new boat owner might want a freezer, FWIW.
Mar 16, 2021
93
hunter 41 DS tacoma
I snipped the connector & now I will get a refer stat for the freezer. Thanks y’all
Jun 1, 2016
162
Hunter 28.5 Lake City, MN
