On my DC side of the electrical panel I have all breaker switches except one. The one is a bus fuse. I checked the fuse and it is blown. It is a 20 amp. The problem is; I don't know what it is for. Can someone give me a hint?
I don't think its my bilge pump because it is working. The automatic unit is external to the panel and has only a pilot light on the panel indicating that it is on automatic. I checked its function the other day and both the automatic and manual features are working. My other bilge pump is manual and has a breaker to turn it on.My 37.5 had a similar setup the fuse was always hot, even with the main CD breaker off. If powered the bilge pump. Pull the panel to check if the power wire goes directly into the wire loom and the fused wire leades to the auto-on switch (probably right below/above it)
Pulling the panel is very easy just take out the screws around the outside and lower it with the hinge.
I have a glass fuse middle bottom of DC side of panel, labled "bilge pump" the fuse is missing and the pump works fine on auto/float switch and manual turn on.
But where is your panel mounted Don? That's does not look like the area on port just above the end of the nav table.
My pannel is like the one on the last pic. The fuse is for the bildge pump and mine does work, the light comes on when the pump runs on auto, and the light near the manual switch comes on when the pump is turned on manuall.
I Think a great addition to any boat is a digital counter for the bildge pump. You leave the boat you set it to zero. when you return you can see how many times the pump has been runnig while you were gone. It is also great on long trips expecially when motoring because you cant hear the pump run whith the engine runningl.
