H34 toe rail
Aug 12, 2019
14
Hunter 34 Wilson, ny
Hi everyone
Stripping the hardware off the deck of my h34 to repaint and wondering if I should remove the toe rail as well?
Thanks!
Jan 24, 2017
672
Hunter 34 Toms River Nj
No you can't remove it is sandwiched between the hull and the top decking. You would need to rebed the deck to hull joint. Just paint around it.
Apr 22, 2011
976
Hunter 27 Pecan Grove, Oriental, NC
I agree with others that you should not remove the toe rail to paint the deck, just tape it off. It can be removed though if you don't mind removing about 140 hard to access nuts on the underside of the deck! There is a black mastic like material that seals the rail to the deck, but is is pretty soft. As you can see in the pdf, there is a source for the Cherubini Hunter toe rails even today.
