H34 Spinnaker Info?
Rick
Oct 5, 2004
1,098
Hunter 420 Passage San Diego
What length is everyone using for a Spinnaker Halyard. Also how well does the UK flasher work holding on to the roller furling? Seems to me like it would irritate the jib? Thanks!
Rick
Oct 5, 2004
1,098
Alan
4,174
Hunter 35.5 LI, NY
Re: Spinnaker Info
A spinn halyard for any masthead boat is 2 1/2 times the mast height. For a frac rig it's 2 1/2 times the "I". The tack line of a cruising spinnaker does not attach to the forestay (or the rolled headsail). It is run through a turning block at the bow so that it can be adjusted for varing points of apparent wind.
Alan
4,174
Hunter 35.5 LI, NY
Re: Spinnaker Info
Rick
Oct 5, 2004
1,098
Spinnaker Tack Line
Alan, I know the line is not attached to the head stay/Roller Furler but The UK one comes with a sleeve that does and that is the peice that I am inquiring about.
Rick
Oct 5, 2004
1,098
Spinnaker Tack Line
Alan
4,174
Hunter 35.5 LI, NY
Re: Sinnaker Info
Rick, are you refering to something like the ATN Tacker? This thing restricts the movement of the spinnaker luff. I would not use one of these things. Daryl, Your spinnaker halyard is way too big and not long enough. If ever you drop your chute in the water, you'll wish like hell you had a longer halyard.
Alan
4,174
Hunter 35.5 LI, NY
Re: Sinnaker Info
Bill O'Donovan
Pole
If you're looking for a spin pole to throw out over the bowsprit, email me at bodonovan@vgazette.com for free pix and directions.
Bill O'Donovan
Pole
Jun 7, 2004
91
Hunter 34 Selby Bay
Alan: Which is correct?
The top of the mast on a H34 is 46' from the top of the doghouse. Thus, 46' x 2.5 = 115'. The mast height from the waterline is about 51.5'. If that's the measurement to use, the halyard should be about 129' (51.5' X 2.5) long. Which measurement method is correct? ~ Happy sails to you ~ _/) ~
Jun 7, 2004
91
Hunter 34 Selby Bay
Alan
4,174
Hunter 35.5 LI, NY
eds928gt :eek:
The correct length is based on the height of the mast above the deck. Daryl is quite right about the halyard length for his 34....my mistake for not doing the math correctly. I used my mast height instead... 50 X 2 1/2= 125 Sorry for the screw up!!
Alan
4,174
Hunter 35.5 LI, NY
eds928gt :eek:
Jun 3, 2004
275
- - USA
115' worked great on my Cruising Chute
Never wanted to deal with that pole thing on the racing spinnaker
Jun 3, 2004
275
- - USA
Alan
4,174
Hunter 35.5 LI, NY
Daryl.......
The reason for the length of the spinn halyard has nothing to do with the type of spinnaker. It is the fact that it is a spinnaker that matters. As the halyard is released to drop the spinnaker, it can take off and wind up in the drink. That's when a long halyard is what saves you from having to cut it loose. I'd rather deal with a little extra line. Your 115' is the right length.
Alan
4,174
Hunter 35.5 LI, NY
Daryl.......
