I am trying to install a masthead wind sensor. Has anyone successfully installed a new wire through the mast step without removing the trim on the head door. I can get a fish tape in through the bottom, but it stops at the step. It seems the tube through the step does not line up well with the channel. There is also a ton of silicon in the tube.
Removing the trim would require drilling out wood plugs over the screws which I hoped to avoid.
1986 model
1986 model
