H30 Cherubini bow storage question
kito
Sep 13, 2012
2,011
1979 Hunter Cherubini 30 Clemmons
Just curious if others with H30's ever cut an access door into the bow panel in the v-berth. I did yesterday and installed a matching hinged door. I was surprised to see a huge unused storage area in the bow that Hunter decided not to use. It may not be the same on all Cherubini's but my 79 H30 sure didn't have access to that area.
bmjpv
Oct 3, 2014
14
Hunter 37c' Vonore Tn
Me too !!
I too only got the toe room I needed by removing the lower locker . I've got a 79' hunter 37c for the record.
kito
Sep 13, 2012
2,011
I never been on a H37c. I would think the v-berth is bigger than a H30....maybe not. I am 6'5" and can lay down straight in my v-berth. I didn't need to take down the panel for room. Sure is nice to have some extra storage space though.
malyea
Dec 15, 2009
236
'87 Irwin 43 Sea Breeze
On my '82 H30 there's a lift off access panel under the v berth cushions into that forward most compartment.
Oct 6, 2007
1,172
Hunter H30 1982 Chicago IL
No "bow panel", with or without a door, at the front of the V-berth in my '82 H30. Just an open area to shove the center cushion and a rolled up comforter into.
Do have the forward locker under the v-berth with access panel under the cushions.
Apr 16, 2014
94
Hunter 27 Brick, NJ
My H27 came with area already opened up, with the main V-Birth cushions measured to fit inside of it. Its nice to have that space becasue it provides a full length bed for me and one other person if I wanted. I can't immagine being able to use the V-Birth as a sleeping space without it.
Alctel
Dec 13, 2013
264
Hunter 36 Victoria
My 36 came with an open hole for that area, under the anchor locker. I keep my socks and underwear in there
I AM about to install a door into the space under the V Berth - having to pull up the vberth cushions and sheets to get in there is a royal pain
Apr 8, 2014
12
Hunter 30 Fort Walton Beach, FL
kito - mine 79 H30 came with a door there. Evidently a PO had the same idea as you. There is A LOT of storage area there.
Jun 21, 2007
2,118
My Cherubini H36 came with a screw attached panel that separated the forward part of the sleeping cushions section and the (say) further 5' toward the bow. I have removed the panel since long ago when I required access to the forward area for toe rail bolt tightening, leaks associated with the bolts for anchor roller and the anchor windlass, and also to tighten the bolts securing the bow stem piece to the FRP hull. After several removals and re-installations of the panel for these tasks, I eventually realized that other than for aesthetics, the panel wasn't really needed.
Yes, I now have a few extra cubic feet to stuff stuff into.
Underneath the interior "deck" on which the V-berth cushions reside, the Cherubini Hunter 36's have a large void space. Hunter supplied a hatch opening to this area for storage. This hatch is what Actel refers to being aggravating.
braol
Apr 16, 2014
348
Hunter 27 Rebel 16 Great Lakes Naval Base, IL
My H27 has an access door but the area was used for an anchor chain locker, complete with a hawse-hole cut into the deck....chain since removed, hawse hole soon to be covered by a retractable bowsprit....
Nov 17, 2014
13
Catalina 30 3099 Louisville
That's how my 77 H30 is.
