I finished installing my MSD Pottie with pump out. Even though my boat came with a new/never used Dometic 976, I bought a new Dometic SeaLand 5.0 Gallon SaniPottie 965MSD. I had these before and know they are almost indestructible and last many years. I read several reviews about the Dometic 976 that the tanks cracked or the plastic flush handle shaft broke, I decided I didn't want to take a chance on it. The shaft on the SaniPottie 965 is stainless steel, it's design is simple and replacement parts are readily available.
My 94' H26 does not have conduit from the factory running under the aft berth to the stern compartment. Installing conduit is very difficult as the space below has foam and access is difficult. I know this because I did run a 3/4" conduit from the aft compartment to the galley and it was a very difficult job, even with the smaller conduit. To install a waste hose through there would be next to impossible. For those with a 260, you're really lucky to already have the conduit in place. I wish Hunter would have thought about that with the early H26s. Hunter did run one electrical conduit through the starboard coaming for the DC electrical panel, but there is no more room to install additional wires. I had no success running another 3/4" conduit through the starboard coaming, so I had to go under the aft berth to the galley.
I ended up running the pottie waste and vent hose through a 3" conduit I installed in the port coaming, which is completely hidden from view in the aft berth. I was also able to run a 3/4" water line for a transom shower through the 3" conduit, and still have room left over if I need to run any wires.
In order to install the 3" conduit, I first cut a 3-1/2" hole in the aft end of the hanging locker.
Due to the foam flotation, it was somewhat difficult, but I was able to insert the 3" conduit all the way back to the aft compartment without removing any foam.
I made a trim ring cut out from a cutting board.
This is the 5 gallon tank with hoses connected. The nice thing about this MSD, is that if there are no pump out stations available, the caps that came with the unit can simply be screwed on enabling removing the tank for manual dumping.
Here you can see the deck fittings connections inside the aft compartment.
I decided to install the deck fittings on the stern. There is no wood to be concerned with there, and being a vertical surface reduces the chance of a leak.
I intend to install a cover/shelf over the compartment, to further hide the hoses.
