H-23 Head Sails
Joe, I have an 86 H23 and use a 155% all the time. You will have no problems with this sail. The 23 sails very nice with the big head sail. I use mine in anything under 15 kts of wind. Then I drop down to my 110%. You will be quite a bit faster with the larger jib.Only thing to remember is after you tack, to slack sheets until your boat speed is back, then pull in and go.This is due to the short stubby wing keel. If you don't pick up some speed you will just sit there and crab. ScottH23 "No Alibi"#598
