I recently replaced turnbuckle ends on the side wires but not the forestay. Anyone who has raised the mast without being careful has probably bent a few of those turnbuckle ends accidentally. Whoops...
Now, even with the forestay as short as possible, my mast foot does not set flush with the mast support (See picture). I followed the procedure in the H19 manual for setting mast rake/tension. I've tightened/loosened/re-tightened several times but was unable to ever get the foot to fully seat.
With the boat level, I could also not get the wrench hanging from the main halyard any closer than 12" from the rear of the mast. Per procedure, it is supposed to be roughly 6" aft of mast at the boom.
I took it out on a lower wind day and with mainsail only did not see movement or loosening, but the boom seemed low in the cockpit and sail was "loose".
My question is whether or not this mast position is normal. If not, do I need a new forestay? All new standing rigging?
Thanks!
Thanks!
