I am re-routing some duplex wiring from the bilge pump to my battery in the aft battery compartment. I would like to "tack" the wire to the surface of the aft berth with a low profile wire clip, but of course, don't want to drive a screw down into a "wet" area below. Does anyone know what is directly below the area between the bilge and the port side of the battery compartment? (water ballast tank? deep blue sea?) If driving screws is not a good idea, I may resort to some type of adhesive to hold down the wiring. Any thoughts would be appreciated. Thanks, BrianW
