Green mold on lines
Nov 19, 2009
289
Hunter 45CC Ft Pierce and Abaco Bahamas
Best product and procedure to get green mold from the running rigging?
Thanks in advance
Ron
BrianW
Jan 7, 2005
843
Hunter 26 Guntersville Lake, (AL)
It would be very unusual for mold to be growing in direct sunlight on a mostly dry metal surface. Are you sure it’s not corrosion?
Beneteau 323 Annapolis MD
do you have a way to avoid the complete spaghetti after the wash cycle?
Soak it in a tub or the washer overnight. I coil it, either tie it in a knot or put one tiewrap on it, put it in a mesh laundry bag and wash it with a load of towels or something bulky.
A bucket and warm soapy water. The green is algea not mold. Do not use a chlorine based bleach, like Clorox.
Likes: RWSlater
Nov 6, 2006
10,205
Sodium hypochlorite (bleach) based stuff will get the green out but it reduces the strength of the line significantly.. better to use soap/detergent and water.. There was an article in Practical Sailor a couple of years back that tested strength of lines/ropes after cleaning in various solutions..
Likes: RWSlater
Nov 19, 2009
289
I would like to clean them on the boat and take it all down.
I use Jay the Dirt Farmer’s cord chain style to wrap up loose line. Then put it in the mesh bag and give it a wash. Tumble wash or soak in a tub. Soap and water.
After wash hang it up to air dry.
Line stays in the chain. When released it is not twisted. Runs out straight. And not spaghetti.
