Gray water question
34
Catalina 30 sheboygan WI
Purchased a 1979 oday 25 late this summer, and have been opening hatches and crawling around trying to become familiar with her. I noticed that the sink in the head drained to a thru hull, but when I checked the sink in the galley, the gray water didnt exit any thru hull because there wasnt any. Instead, the drain hose was connected to a gate valve plumbed into the hull. Where does the gray water go, and what is the seacock for?
Bill Coxe
Gray water
The head sink drain goes to a through-hull that is above the waterline and supposedly doesn't require a seacock. the galley head goes to a below-the-waterline thru-hull, and therefore DOES require a seacock. We have found on our O40 that given sufficient heel and speed, we can get sea water to back up through the head sink, especially if there is significant pitching. i believe that that is the ratinale, so to drain the galley sink, open the seacock and close it when done. Hope this helps. Bill Coxe, O40 Kukulcán, New Bern, NC
Aug 8, 2007
34
Gray Water
Just did an archive search on my question (should have done this before the post)and got the answer. Great thing about boating is there is always something to learn. Hank
