GOING TO WEATHER
R. KELLY
WHATS THE TRICK TO GET A ODAY 25' TO GO TO WEATHER BETTER. TIP THE MAST AFT A LITTLE? WHEN RACING WITH OTHER 25'ODAYS IT WON`T GO TO WEATHER WITH THEM. SAILS ARE IN GOOD SHAPE. ANY HELP OUT THERE. USE TO RACING C 25 BOAT.
Justin - O'day Owners' Web
Well . . .
That's a hard question without access to the boat. Some things to look at - Keel and rudder - they provide the lift to take you to windward. Are they fair? Clean? Disturbed flow over the keel will kill your pointing ability. Bottom - the hull bottom fair? Clean? The faster you go the higher you can point, to a point. If you're losing boat speed to a messy bottom you're losing pointing ability as well. Travler and Genoa lead car positions - the easiest thing to do is ask the other O25's how they're setting their lead cars and travlers. Halyard tensions, outhaul tensions, cunningham, vang on and on - it all matters, that's why its there. I'd suggest getting someone off one of the other O25's to sail with you. That'd be the fastest way to learn. Justin - O'day Owners' Web
R.W.Landau
Sail shape
R. You said that your sails are in good shape. Is your sail shaped good? A full sail is not the best for going to weather. Flatter sails tend to allow you to point higher. I agree with Justin and his advice. One thing you can do is to put "tell tales " on the jib and main. This will tell you alot about how you are trimming the sails. Are your sails the same size as the other 25 O'Days? I would do as Justin suggested. Sail with one of the other 25's to see how they handle their boat. Check the sail size and shape while you are aboard. I do have my mast vertical. It has helped with weather helm. r.w.landau
MArk
Telling tails/tales?
Hey R., Check this site on how to use telltales. Happy sails _/), MArk
