I have had a '77 C-22 on Lake Erie for the last 4 years. The PO had, what I assume, was the original sails, a 135 jib and a footed main. It also came with this multicolored 'Gennaker' that wasn't made for the boat. I replaced the main in '09 and the 135 is pretty much blown out so I need to replace it.
When I sail on the big lake, winds and waves can build quickly. The 135 is OK for winds over 10 knots but not so hot for less, depending on the number on board. The 'Gennaker' measures out to be the equivalent of a 185. It is made of light clothe which I believe is ripstop nylon. A few years ago I went out in light winds and hoisted the Gennaker in light winds coming back, the winds picked up to about 10-12. Fortunately I had 4 other adults on board so I had enough rail meat and the waves didn't have time to build so it was a great ride. When I single hand, which is often, it is too much especially taking down.
So I've pretty much decided to go roller furl with a 150% jib on a CDI FF2. This Gennaker has a wire in the luff. I don't think it was made for the C-22. The PO tied knots in the wire to shorten it so when hoisting it will tighten. Not very elegant but is works. It also has hank on clips.
Now for my question, finally, should I keep the Gennaker for the days of light winds? I can leave the jib halyard in place. The CDI has an internal halyard so I don't need the one on the mast. The internal wire should act as the forestay, although not as tight and straight as the forestay, I would only use it in light winds and crew on board. The furler will allow me to single hand and reef the foresail from the cockpit when single handing. I would probably remove the hank on clips.
