Generators - kW needed for 40 to 45 foot Hunter
Oct 29, 2016
1,929
Hunter 41 DS Port Huron
@ice breaker I purchased new relays and a pump I never installed them, seems if I run the genny regularly it would start without issue as long as I preheated for a minimum of 20 seconds prior to starting. The research I have done is pointing to a check valve internal to the pump and the pump is not to bad to get to, so the task is on the off season list. Trouble is I wouldn't be able to prove out the fix until she goes back in the water in the spring.
Oct 5, 2015
33
Hunter 38 Auckland
James, Jerry and Daydreamer,
Thank you ALL for your replies - fantastic information to start from!
Will make my decision when back from Xmas Sailing holidays - we are off for 2-3 weeks to go up north
Merry Xmas and Happy New Year ALL!!!
Likes: JamesG161
