Gelcoat over Epoxy
From time to time, SBO members as if gelcoat can be applied over epoxy. This question usually comes up in a discussion about hull repair and whether the repair must be done with epoxy or polyester resin. The answer to the question is, yes gelcoat can be applied over properly prepared epoxy. West System recently released a video on this topic and demonstrated there is little to no difference between gelcoat adhesion to epoxy or polyester.
colemj
Jul 13, 2004
1,033
Good to see this myth put to rest. I've used gelcoat over epoxy many times with no issue, but I've stopped trying to convince others because of the strongly held myth that it can't be done.
Just make sure the epoxy is fully cured, any blush is removed, and tooth it aggressively. I didn't watch the video, so they may suggest differently than this, but I've had no problem with my method.
I'd nitpick that there is no difference in adhesion. I'm fine with the conclusion that adhesion won't be an issue, but if gelcoat is applied over laminating polyester (or vice versa if using a mold), there is a strong chemical bond between the two that does not exist with epoxy. With epoxy, it is all mechanical bonding.
But this mechanical bond still works in practice.
Mark
C&C Frigate 36 St. Margarets Bay, Nova Scotia
...I'd nitpick that there is no difference in adhesion. I'm fine with the conclusion that adhesion won't be an issue, but if gelcoat is applied over laminating polyester (or vice versa if using a mold), there is a strong chemical bond between the two that does not exist with epoxy. With epoxy, it is all mechanical bonding.
Mark
I am not a chemist, but I believe that chemical bonding of polyester to polyester happens while polymerization is still occurring - while the resin is still 'green'. This happens when gelcoat is sprayed in the mold and then polyeaster resin (and fibreglass) is applied on top. On repairs of cured fibreglass, you are dealing with straight mechanical bonding, which is why epoxy is preferred for its superior adhesion. So, applying gelcoat to either type of substrate is pretty much the same.
Likes: dLj
I don't disagree, however, the video seems geared towards repair work done by DIYers and yards who prefer to use epoxy for repairs.
Jun 21, 2004
3,093
Beneteau 343 Slidell, LA
Using composite resins throughout my career, I was always taught that chemical bonding occurs when multiple layers of resin are applied to an uncured substrate; however, once the resin is completely cured & amine blush is removed, additional layers form a mechanical bond only. That’s not to say that mechanical bonds are insufficient for a specific task; however, bond strength will never approach that of a true chemical bond.
