Gel Coat Spider Cracks
brsch
Jan 19, 2014
3
Hunter 22 Port Charlotte
Is there any way to fill in spider cracks and somewhat cover them up?:neutral:
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
Not really
when my new Hunter had some spider cracks and the dealer had a pro do it
he used a small grinding tool on the surface and over it with some kind 2 part
west system I think and than sprayed some new gel coat.
Filling them just a short fix.
Nick
Jun 9, 2008
1,847
- -- -Bayfield
Not recommended to use epoxy as gelcoat has an issue with it. I'd use polyester. You cannot just cover crazing as they will soon appear. You have to grind them out, glass them up and refinish with gelcoat (or paint, if you are doing a total recoat).
