David
I have a 1975 C27 and have discovered some pinhole leaks in the old gas tank for my A4. I have a few questions about what I should do and what I am going to find when I go to take the tank out. I'd appreciate any help you can offer.1) I'm inclined just to replace the old tank and the hoses. What is the best, most reasonably priced replacement? I have a dinette model 27, if that matters.2) What holds the tank in place? I can't see anything from the vantage point I now have. 3) What's the best way to strap down a new tank? 4) Is there any reason I should haul the boat to do this job? I guess siphoning out the gas would be easier... 5) If you've done this job, what do you know now that you wish you'd known when you started it?
