Garelick or Panther Outboard Motor Mount
34
- - Toledo, OH
I have searched the archives of this site, but didn't quite find the answer I was looking for. I have an O'day 25 that has an older motor mount on it. My motor weighs approx 125 lbs (Mercury 9.9 four stroke - long shaft). It is a struggle to lift it up. I have looked at both the Garelick and Panther motor mounts for 4 stroke engines not weighing more than 160 lbs. I even contacted both, but neither could really tell me how easy it would be to lift my motor using their mount (which I understand as it is subjective). I asked both if they had dealers in my area, Toledo, OH, that might have a demo that I could try - neither one said they did.
My question is if any of you have either Garelick's or Panther's 4 stroke motor mount and how easy it is to lift your motor? If you could specify how heavy your motor is for comparison that would be helpful. I understand nobody can guarantee an answer since we all vary in body strength - easy for one person is difficult for another - but I hate to spend money on a new motor mount only to find out it is not any easier to lift the motor than my current motor mount.
Thanks,
Joe
Johnb
Hunter 37-cutter Richmond CA
When I had an outboard on a motor mount I rigged a couple of blocks to make lifting it easier.
My Honda BF100 weighed 80 some pounds (4 stroke 10 HP). 125 for 10 HP is very heavy?
Dec 28, 2009
397
Macgregor M25 trailer
Joe,
I have a 9.8 Tohatsu ~100 lb on the Garelick 71091 mount and have no trouble raising or lowering it, other than it is a long reach down when it is lowered. I'm not as spry as I once was, I'm in my mid 70's.
Fred
Apr 15, 2009
76
Hunter 27 beacon ny
I have a 15 HP 4stroke Yamaha 20inch shaft on my Garelick about 130 pounds..comes up easily. I have it on a 79 H27 down low stbd. corner of stern. I often raise it under way while running to lower drag and place plate just below water line. Moves my boat at hull speed with half throttle at that setting.
Sep 27, 2008
95
Catalina 30 Lake Champlain
Joe, I replaced the original (very wimpy) motor mount on my 1983 O'Day 23 with a new Garelick. Like others who have responded to your question, I found the Garelick mount worked very smoothly and enabled me to lift my motor very easily. I had a Honda 7.5 hp that weight 85 lbs. With my old mount, I had to struggle to lift the motor clear of the water; with the new mount, the motor sprung up easily once I released the locks.
Bob
