Galled stanchion removal
DArcy
Feb 11, 2017
1,788
Islander Freeport 36 Ottawa
If the trouble is the holes don't quite line up then just drill them slightly over sized.
Apex
Jun 19, 2013
1,225
C&C 30 Elk Rapids
Looks like the bases are still bent a bit. short of a work bench mounted vise, try adjustable pliers. Not enough, warm it with propane torch.
Sep 24, 2018
4,693
Catalina 30 MKIII Chicago
Try using a ratchet strap connected to another fitting on the boat to pull in in the direction that it needs to be bent. A winch and line would be even better if the angle is correct
Likes: jdrutten
