I have a FY2000 Hunter 380 with the standard Marine Air Systems AC unit model number VCP16K. It has the Passport II control module. The problem is the measured temperature runs up when the AC is running. It starts at about 80 deg and slowly runs up to 120 degs. Because the measured temperature is so high, the AC never turns off in the summer and I can not get the heat to turn on in the fall. Having found and read a couple of manuals online, it seems the temperature sensor is in the control module.
Has anyone seen this problem before? Any thoughts on replacing the control module to solve the problem? Any other good ideas?
Thanks!
Thanks!
