Fuse ratings
Jul 4, 2015
436
Hunter 34 Menominee, MI; Sturgeon Bay WI
The voltage is a maximum as some others have said. No harm done from using a 24V, 110V or 240V fuse in a 12V circuit, it will still blow at its maximum ampacity.
For those saying the fuse blows because of power, which is V * A, you are technically correct. But the V in that equation is the voltage drop across the fuse, not for the circuit as a whole. A fuse is a very low resistance - it’s not generating a 12V drop or that would leave no volts for the whole rest of the circuit. An ideal fuse produces very little voltage drop, so it doesn’t dissipate energy as waste
NOW I GET IT!!! Thank you!
Jul 4, 2015
436
When faced with discussing what feels like a simple subject, yet the discussion sounds confused, I resort to identifying the data. Stated in post 7 @Ilanortho says the books are not identifying the issue.
Perhaps this link will help.
In review some of what has been stated by all is valid.
Thank you; interesting site. Will keep me busy for a while.
436
Ohms law really doesn't apply*. At normal current levels a fuse is much more a wire than a resistor. If a fuse ever measures at 2+ ohms it's a bad fuse.
TLDR:
Current blows fuses**.
Voltage is important for arcing as explained above.
Fuses should (may) have different max voltage ratings for DC vs AC because of the arcing issue and some may be specific for AC or DC.
Fuses used on boats should be ignition protected, particularly for high loads.
The purpose of the fuse is to protect the wire - i.e. the fuse burns inside it's protected case before the wire burns inside that nice wooden cabinetry which may cause a bad day on the water.
* Well, reeee, yes, ohm's law always applies somehow, someway. But not to calculate anything about fuses from a user's perspective. Nobody really needs to care about all that except for the person designing the fuse.
** Really it's current + time. But we don't really care that much because the wire that's being protected also has a time factor before it bursts into flame, and that time should be greater than the fuse if the wire and fuse was sized correctly. Example, how a Blue Seas MBRF fuse reacts to current over time:
So, for minor overcurrent situations, it could take quite awhile to pop this fuse.
This is why MBRF's and other large fuses are perfectly acceptable to be used on batteries that provide starting power to boat engines. (There's a MaineSail article on this)
Thank you!
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
If you use Ohm's law to get the fuse resistance 24=10 amps (R ohms), then the fuse calculates as 2.4 ohms
That's incorrect.
Am I wrong?
Yes, you are wrong!
Correct
No, Don, that's incorrect
If a 12V fuse rated at 10A is in a circuit using 24V, the fuse will blow even if there is no current flowing.
Incorrect.
The voltage rating of a fuse is the maximum voltage that it can safely interrupt.
More precisely, withstand. But the details are more complicated.
Voltage drop across the fuse is going to be near zero whether the source is 24 V or 12 V until the fuse blows, at which time it will be either 24V or 12 V
Correct! We have a winner!
I don't like to appeal to authority, but I'm an electrical engineer. I am appalled at the incorrect information that people supply here as answers to this question. They demonstrate a lack of understanding of fundamentals of circuits and devices.
Likes: LloydB
Jul 4, 2015
436
That's incorrect.
Yes, you are wrong!
Incorrect.
Agree with all of the above rectifications. Thanks because I had the same concerns.
Don't be appalled; My diesel guy feels the same way about the engine I tinker with. Read a whole bunch of books carefully - enough to be dangerous. But smart enough to know the danger present and that I needed to get this cleared up.
Feels really good to get these answers to something that was bothering me for a long time and just couldn't seem to figure out - wrong basic assumptions were incorrect (as usual) creating a roadblock to the correct answer.
Tater
Oct 26, 2021
198
Hunter 170 Lake Logan Martin AL
....I don't like to appeal to authority, but I'm an electrical engineer. I am appalled at the incorrect information that people supply here as answers to this question. They demonstrate a lack of understanding of fundamentals of circuits and devices.
Way, way back in a former life, I asked this question of my Navy instructor. I knew his answer was BS but nodded as if I understood. I kept searching until the truth came through. The problem at the time was that reference books didn't have a search engine.
Likes: Ilanortho
Tater
Oct 26, 2021
198
While we are on this topic, I will share some info. Someone mentioned batteries. If you want to see a good fire, short the battery through a length of wire. First the insulation burns and if the wire is small enough it will burn. The resulting fire can be spectacular. Always keep a fuse in-line as close the the battery as possible.
I have a battery at home for emergency lighting and backup power for my ham radio. You can bet that it is fused.
Likes: jviss
Jun 11, 2004
1,862
Oday 31 Redondo Beach
That kind of reminded me of what Dylan said:
Half the people can be part right all of the time, an'
Some of the people can be all right part of the time,
But all the people can't be all right all of the time.
jviss
Feb 5, 2004
7,090
My batteries all have fuses right on the terminal: MRBF's on thermal blocks from Blue Sea Systems.
MRBF == Marine Rated Battery Fuse
I think mine are 100A. You can do a lot of damage with 100A, but at least you won't blow up the battery or melt the (properly sized) wires.
MRBF Terminal Fuse Block - 30 to 300A 5191
Likes: Ilanortho
jviss
Feb 5, 2004
7,090
Since we've gotten off track here, anyway, here's an explanation of how a fuse might behave in a circuit.
On the left we have the circuit during normal operation. Let's say the battery is 12VDC, R1 is 1Ω and R2 is 1Ω. The fuse is a 10A fuse. In normal operation I1 and I2 are equal, I3 is zero. The current is 6A: 12V/2Ω. V1 = V2 = 1/2 the battery voltage = 6V, assuming the resistance of the fuse is zero. When the fault occurs - represented by the switch, "S," closing - for a moment the currents I1 and I3 become 12A, I2 goes to zero, V2 goes to zero volts, and the fuse, "F," blows. When it blows it opens, and all currents go to zero, and V1 goes to 12V.
Note that in normal operation V1 and V2 are (virtually) equal, and after the fuse blows the voltage across the fuse, V1 - V2, is the battery voltage, 12V.
Likes: Ilanortho
jviss
Feb 5, 2004
7,090
You can fast forward it to the 44 min mark
Thanks. That's actually pretty good!
There's a way to share a youtube video starting at a particular point. Here's this one starting at about 44 minutes:
Tater
Oct 26, 2021
198
No lesson is complete without a test. Is the lamp on or off? Sorry for my crappy artwork. You can only do so much with
Paint!
jviss
Feb 5, 2004
7,090
Paint!
It would appear that it's on, since the circuit is complete. But, you don't say what the battery voltage is, or what the rating of the lamp might be.
Tater
Oct 26, 2021
198
You are thinking too hard. The lamp is OFF because that is a BLEW fuse.
Sorry, all this brought back memories.
Likes: jviss
Jan 26, 2019
70
Catalina 30, mkI 2462 Waukegan, IL
A 10A fuse can handle 10A. Period. Aside from the interesting AC/DC arcing discussions, voltage difference provided to the circuit is irrelevant, since it's NOT what the fuse will see under normal operating circumstances.
In the case of "oops"--a short circuit or other abnormal situation--the fuse might see the total voltage difference provided to the circuit. If this occurs, then the fuse will do its job and melt in a hurry.
There really is no need to bring up the math for Ohm's law and power, especially if you want to use 12V, 24V etc. for voltage in these equations. Keep in mind the fuse will generally only see a very very very (did I say very) small chunk of the total voltage being provided to the circuit.
Peace,
Josh (a calculus based electricity & magnetism instructor)
