Call around
and look at other boats. See what furlers are popular in your area.Compare features and pricing for Furlex, Harken, Pro-Furl, and Schaefer. They all make good furlers.Base model Furlex units have no headstay adjustment, adjustable length is an $$$ option. I think you will find that the Furlex is more expensive than a Harken after you add the adjustable drum.As far as installation and ease of use ...They all work about the same.You can install a Furlex, Pro-Furl, or Schaefer yourself. You will need a rigger to put the stud on the Harken (or use a Sta-Lok stud).As far as after installation maintenance and repair. The Furlex is a bugger to work on, the Schaefer requires special rivets that may be hard to come by. The Harken and Pro-Furl units can be serviced and need little/no maintenance.
